I just picked up a '89 festiva after years of being without one. I've got an issue with it. The heater is not very hot on any setting but when I set the mode all the way to the left on panel vents there is no heat at all. What can cause this? I check to make sure the blend door isn't moving with the mode lever for some weird reason. No problem found there.
