Seeking opinions on any of these $100 drive shaft pullers
  • Seeking opinions on any of these $100 drive shaft pullers
    Here's what I've found:
    The Specialty Products Company 499 Flange Type Axle Puller is a robust, professional-grade tool designed for the safe and efficient removal of flanged axles. Engineered to meet the demanding requirements of automotive workshops and industrial environments, this axle puller provides technicians with a reliable method to service a wide array of vehicle types, streamlining maintenance and repair tasks. Key FeaturesSecure Flange Engagement: Engineered for positive and effective engagement with flanged axles, ensuring a controlled and consistent pulling operation without slippage, which is critical for precision work.Durable, Professional Construction: Built from high-strength materials, this tool is designed to withstand continuous use in challenging automotive and industrial settings, guaranteeing longevity and consistent performance.Component Protection: Designed to apply even and distributed pressure during the removal process, significantly reducing the risk of damage to axles, housings, and other critical drivetrain components.Optimized Technician Efficiency: This specialized tool simplifies the often-challenging task of axle removal, enabling mechanics to complete repairs more quickly and effectively, enhancing overall workshop productivity.Enhanced Workshop Safety: Provides a secure and controlled method for axle extraction, minimizing the reliance on improvised or potentially unsafe removal techniques.ApplicationsThis specialized axle puller is an essential tool for various automotive service and repair tasks, supporting the integrity of vehicle drivetrains. It is commonly used for: Rear Axle Removal: Facilitates the safe and effective detachment of flanged rear axles from a broad range of vehicles, including passenger cars, light trucks, and SUVs.Wheel Bearing Service: Provides crucial access for the inspection, removal, and replacement of rear wheel bearings, a key component in vehicle suspension and handling systems.Drivetrain Maintenance and Repair: Ideal for tasks requiring the disassembly of drivetrain components where a flanged axle must be safely separated from its assembly.SpecificationsWeight: 10 lbs
    with this fork:
    OR
    (Puller on 1st line, ford on 2nd)
    OR
    (comes with what appears to be suitable fork)
    I've got a '91 up on jacks and spent a whole day trying to get drive shafts out -- BOTH sides are stuck solid. Tried all tricks found on this forum. I have a '93 in line behind the '91.
    It's time to start throwing money (each product is only about $100) at the problem!
    88L black, dailydriver
    88LX silver a/c, dailydriver
    4 88/89 disassembled
    91L green
    91GL aqua pwrsteer
    92GL red a/c reardmg
    1952 Cessna170B floatplane
    The last problem removal was successfuly done with vice grips and a sledge hammer. Just remember not to remove both from the transmission without first sticking a dowel in to support the gear, so that it doesn't fall down when you remove the opposite side. You may now Paypal me the $200 consulting fee.
      I used the slide hammer and puller piece. Problem with it is it pulled the threads out of the puller piece!
        As I indicated, I want to throw money at this. I've changed many a Festy driveshaft over the years, and had my share of nasty ones, but never two on the same vehicle. I want a solution with 98% or better success rate.
        Bravekozak ... I know about not removing both sides simultaneously, so will reduce your consultation fee down to $0.02. You could earn more if you'd point me to illustrated parts breakdowns so I can place a big order with Four Green in time for next summer's 100-day car repair season (when you can work outside) in Anchorage. English required -- I don't know any Russian!
        91L green
        91GL aqua pwrsteer
          Google Chrome will translate the Russian on the fly, and there are pics for the parts anyway. It's more work to just go by the pics cause then you have to click through every one of them, but it does work.
            Here is the one from Grainger on Amazon, save ya $$
            My Musica! Click me!
