Changed head gasket, now hesitation and power loss.
  • Changed head gasket, now hesitation and power loss.
    Hey guys, finished the head gasket on my 1991 Festiva a week ago and haven't been able to drive it around much yet because it has some strange hesitation when starting off or shifting, and a severe lack of power under acceleration.
    I'm hitting you guys up in case it rings a bell with anyone after having their motor apart. Could I have left something unplugged?
    Cam timing is dead on, distributor timing is untouched.
    Thanks in advance!
    Why no, officer. I don't know how fast I was going. My speedometer only goes up to 85...
    -'91 Protege AWD "Familia GTX"
    -'93 Festiva "Abomination of Nature" Gone
    -'91 Festiva "The Wifey's ride"
    Plugs wires crossed ? It's very easy to get that belt on a couple teeth off and engine will still run but with this same result . Good luck
    New build on the way .
      Have you checked compression numbers after the gasket replacement?
        Sounds like timing. Triple check your timing marks line up
        1989 Ford Mustang GT 5.slow
        1996 Ford F-150
          Hey guys.
          Ummmm..... I derped when I should have herped.
          Timing was off a tooth.
          So yeah, cars running great!
            Sweet!
            1996 Ford F-150
