Ok so my car has been acting Up when I'm at a steady 55 on my way to work it every once in a while it will feel like someone reached over and turned off my key. Just for 1-2 seconds top then it's back to normal and 8 can't re create it. It's only happen a few times in the past week sometimes I will do it twice a day and other times I will be fine for 2 day hour each way to work.
Things I have done in the past 5000 miles is
New plugs (ngk copper core)
New wires (ngk blue performance)
New distributor cap (cheapo)
New rotor (cheapo)
New o2 sincer (denso)
New fuel filter.
Things I have checked all ground s cleaned from capri harness (engine).
Also I don't have any codes present but iac witch I have unplugged. .
O and I also swaped out the fuel presser regular selinoid.
Didn't help.
I should have mentioned that I have the b6d from a mercury capri. With all the wiring from the capri.
All capri electronics have about 250 xxx .
40 xxx or so on rebuild and 300xxx or festy.
Any help would be appreciated I need I place to look for the problem.
Could it be fuel pump ? Afm ? Disty? .
I would not be worried about this problem but I commute 120 ish miles per day to work and I Don't Want It to leave me setting along side the road.
New rotor (cheapo)
New fuel filter.
Didn't help.
) If still no curent from coil that would be the logical one to replace first. Car parts cost more here in Canada and I paid about $45 for a coil last fall.
