loss in power.
    Well its official it's not the coil I'm stranded about 30 mind from home and there spark from coil into distributer but nothing out so it's either the pick up or icm.
    I have my dad bringing me my festiva disty and afm I'll have to rewire it and limp it home on b3 injectors.
    I guess when I thought I didn't have fire from coil I was wrong I was trying to hold the screw driver to the strut town and crank by myself and I didn't See it sparking.
      Well I rewired the whole thing to find that I don't have the main relay that goes on the driver side finder so I guess I'm call a tow truck ..... what a long day all Cuz I wanted to go fishing
      Is there any possible way to wire around the main relay?
      I'm screwed , no one has a rrelay or a distributor for me to keep the capri stuff so I cut up my injector harness for nothing ...
        Ok so I got another distributor but I look pretty rough.
        I would like to pull the parts from this one and use them in mine.
        Problem is I can't seem to pull the little 4 side star looking thing off the center shaft to get the icm and pick up out . I removed the screw from the shaft but it wouldn't slide off. I don't want to break it by prying on it. Any suggestions? ?
