hi everyone great forum i just got a 89 festiva i only pay $50 for it ran good. and know the fuel pump stop working but i pulled it and it works fine if i power it with 12 volts and the car runs that way but is there a relay under the hod some place thanks jay
fuel pump relay
Fuel Pump relay should be above the driver's left foot, against the kick panel, 6 position connector with 5 wires (black/red, yel/black, green/red, black, green/yel). And yes, the Vane Air Flow Meter provides a ground to relay coil. During cranking, there should be 12v on yel/black and black/red, and coming out on green/yel. There should be ground on the black wire. When running, ground should be present on the green/red wire, and the black/red should loose power.Jim DeAngelis
Also check the safety cut off switch. That's in the back of the car. Just a small black button on the drivers side, if I remember right. It's underneath the speaker.The Festiva Store
