Daughters car. 1989 Carb Manual. Idles at around 2500 RPM. Choke was doing absolutely nothing so I replaced the entire Carb, mounting gaskets. Still idles high but you can see choke movement. If I manually close the choke the idle comes down. Spraying carb cleaner everywhere, no change in idle. Can not find a vacuum leak. Started replacing any vacuum hose that seemed the slightest bit loose. No change. swapped out the high altitude compensation thing, whatever the heck it is called. No change.
If I rev the engine, sometimes the idle will stick at 3 grand.
Ideas?
Ideas?
