Originally posted by nitrofarm
Completely stumped: High Idle Carby
Try pumping gas pedal? When starting the engine I let it run for about 10 seconds and then press the accellorator to release the choke.
Assume you've tried the white plastic idle adjustment screw on the left side of the carb?
Originally posted by WmWatt View PostTry pumping gas pedal? When starting the engine I let it run for about 10 seconds and then press the accellorator to release the choke.
Oh yeah, I turned it until it does nothing, got it down to 2500. Revving it to let it kick down lets it kick down. You can see the little weighted piece move out of the way, then it idles at about 3K before sloooooooooowly dropping back down.Contact me for information about Festiva Madness!
Tom kind of pointed in the right direction. I would call it the base idle screw. Missing on daughters Carb.
It is where I am pointing here.
Finagled a small screwdriver in there and dialed it down. Viola. Set the rough idle and rolled. Thanks guys!
Running around outside the asylum again with my tappy talky appyContact me for information about Festiva Madness!
Sometimes its that easy-Some people like to read fiction,I prefer to read repair manuals. Weird I know-
If I hadn't been fortunate enough to have another Carb to pull out and stare at for a while, I would still be humped ...Originally posted by nitrofarm View PostSometimes its that easy-
Glad you got it!!!Dan
