just like the title says, on my trip home home ohio stiva last year in my 91 gl i lost all my lights besides brake lights. i had a similar issue in the aspire but lost tail lights and dash lights, still had headlights and it just happened to be the relay under the intake was trashed. i checked all possible fuses and havent found anything.... Any thoughts???huhuhh
Lost all headlights and running lights
-1991 L 238k AC/Cruise Josh's future DD from neanderpaul, the clean slate!
-1991 GL 171k AC/Rust free Jake's future DD (thanks kevin!)
-1993 L B6T swapped auto(thanks rob!) 88k was 123whp 15.8 at 87mph currently undergoing surgery
-1989 LX crazy project car you'll all see one day! (hopefully fm8 )
Have one hydro g and xr2 mid shaft for sale super cheap! PM me!
we have owned 10 of these cars to date and we're only 20 hahah.. call it an obsession!Tags: None
First check if there is any power through the headlamp relay (red/black wire).
If so, then check if there is any power through the the haedlamp switch (red/blue wire).Last edited by bravekozak; 04-14-2014, 06:14 AM.
Did you check the fusible links under the hood?
Fuses in the cabin? I can't remember if one of the fusible links in the engine bay provides power for the lights alone, but it is easy to check those.
Headlamp relay is at front on driver side, running light is at front on passenger side under the intake.
You could have power but have lost the ground lines, that happened to one of my two headlights. So check continuity of ground leads out of the relays.
Combination switch could have failed, mine did for the running lights. After removing the cover on the steering column, that switch connector cable is found on the top of the combination switch on the passenger side with a small clip with 3 wires, one black, two red with different colour stripes.Thricetiva replaced Icetiva as the new ride
Icetiva-3-race-car-build
I lost my headlights once from a fusible link soo.....
Nah, that's way too obvious :pOriginally posted by Aaronbrook37 View PostIt does say "HEAD" on it.
Losing everything at once sounds like a switch issue to me. If you lose parking lights and dash lights but still have headlights then the "tail" fuse under the dash is usually the problem, sometimes when a bulb blows out it shorts out enough to blow that fuse. Losing only headlights but still having parking and dash lights can be either the switch or the "Head" fuse under the hood. But to lose both at once I'd have my money on a switch or wiring issue.No festiva for me ATM...
i will check all these things out when i get home today! thanks guys!i'm wondering if the car has an issue with burning through switches now because i did notice it has the "orange" switches in it which i should have came with white i know that. i'll get home here and get out the multimeter and see what i find and let ya guys know right away!Originally posted by htchbck View PostLosing everything at once sounds like a switch issue to me. If you lose parking lights and dash lights but still have headlights then the "tail" fuse under the dash is usually the problem, sometimes when a bulb blows out it shorts out enough to blow that fuse. Losing only headlights but still having parking and dash lights can be either the switch or the "Head" fuse under the hood. But to lose both at once I'd have my money on a switch or wiring issue.-1991 L 238k AC/Cruise Josh's future DD from neanderpaul, the clean slate!
