I just did the weber swap and now it backfires when i accelerate, would the cause be over fueling or something else? in continueusly blows a couple of my vaccum caps off.
Backfire??
(caution: I don't do carb festivas)
How's the idle? If it idles rough and is backfiring through the carb, check your firing order.~Nate
Current cars:
FOTY 2008 winner!
With the engine shut off, hold the choke open, look down the throat of the carb and move the linkage from closed to wide open. You should see a solid stream of gas squirt into the throat of the carb each time you turn the linkage. If you don't see any gas, your accelerator pump may be bad or your float level extremely low. If you see gas, check for vacuum leaks on your intake, either an uncapped connection or a leaking flange connection.You gonna race that thing?
Check your timing and make sure it is right.
Improper size jets should not cause a backfire. When I first got my weber, it had huge jets in it .... it still ran. It ran rich and bogged some, but ran pretty well for how big the jets were.
And as mentioned, check for vacuum leaks, as they will cause it to misfire.
DO NOT use vacuum caps. They will rot and crack and cause issues within 6 mos. Use vacuum line and connect one vac port to the next one with the line, effectively making a "cap".Dan
both the main and secondary (both found in the bottom of the bowl)Trees aren't kind to me...
Backfire = timing is off
If you have a backfire condition, jets will not fix it
As for the jets, start with .125Last edited by drddan; 05-10-2014, 09:07 AM.Dan
