Odd a/c system from Power Steering Festiva.
  • Odd a/c system from Power Steering Festiva.
    A while back I bought a A/C system here off a guy who pulled it out of a 91' Festiva that had both power steering and a/c.
    Well I have run into a problem, I can't find ANY compatible accumulator/driers under any year for the Festiva on rockauto. I know for a fact it is factory because it is a nippondenso compressor. UNLESS these rare Festivas that had power steering, had a dealer installed a/c system that uses a Nippondenso compressor, but for some reason I don't believe that.
    The closest drier I could find that looks like the pressure lines might fit into is for Dealer installed A/C, but has a weird fin sticking off the side of the canister, the one I pulled off the system was just a round canister, no fin.
    This is the closest thing I could find.
    Find many great new & used options and get the best deals for A/C Receiver Drier-Filter Drier 4 Seasons 33484 at the best online prices at eBay! Free shipping for many products!
    But the fin would have to be cut off, because it will not mount to the condensor with it, that and I am not even sure the fittings are the right thread and size, but still is the only one with fittings set up in this configuration. Everything else has the fittings at a 90 degree angle, or fittings that attach straight into the top.
    Any thoughts? Anyone have experiance with this oddball A/C system that may just end up being a pile of scrap if it can't be used?
    according to the parts books, the receiver/dryer is the same regardless if PS or no PS. (it's mostly just the tubing that is different.) there are 3 different ones though depending on model year. ALL years w/ dealer installed A/C - E7GZ19959A. 90-93 w/ factory A/C - FOBZ19959A. 88-89 w/ factory A/C - E8BZ19959A. it might be possible that the 88/89 dryer was put on at some point? also note in the diagram, the 90 degree fitting config is the correct factory setup.GREEN SALES still has the E7 & E8 parts available. they might be willing to pull them and describe them to you. also, it's been a few years, but i used to go to NAPA to buy fittings and A/C hose to make up custom lines.
      There are seventeen of them left.
      I believe that one has the ports at a 90° angle for the snap on plastic cap.
      There is a another one that is at 180° angle.
        I need the one with 180° ports, what is the part number for that one?
          I have a new one ! Pm me if interested and I'll text a picture .
          New build on the way .
