When I failed to use lock tight on the fly wheel bolts they backed out while driving and made a huggggee mess so now most of the threads on the crank shaft are ether kinda stripped or screwed up whats the next bolt size up I can retap them to the are 12mm by 1.25 thread pitch I beleave could I just go to 1/2" bolts and just tap right down with out drilling since it's between 12mm and 13mm?
From experience whats the easiest way of fixing this quick? I got red lock tight not recommended but I want to over do it
