^^^Video of what's happening. Here's what I did today:
Put in TWO QUARTS of oil. Lost in last 1.5k miles and have had to do this once before. Slowly replacing gaskets as I have time.
New alternator (first one went out 6mo ago, replaced with my only spare that had a bad bearing, today put on brand new)
Put on trailer wiring
Rejetted carb down (main) ONE SIZE, from 105 to 100. I know I know 100 seems small, but the 105 and 110 I had kept acting like it was flooding.
I got my fresh repairs done, smoothed out the idle using vacuum gauge and adjusting timing a bit, and it was running beautifully. I mean, no lag in acceleration, which I've had between the alternator and the carb. I got about 2 miles down the road, everything bogged down, and I barely got back to the storage unit to switch cars.
To get back I seriously retarded the timing and turned the idle way up. I drove back at 11MPH in 3rd as I couldn't get it to stay running/accelerate. I blew out the fuel filter, I checked the alternator, I even took the belt off and started it without the alt and it does the same thing. It sounds bad.
Help?
-Joe
