The 25 amp main fusible link went out in my 1990 Festiva when I accidentally got the + & - briefly REVERSED while installing the battery (hope nothing else went out when I did this!).
I found one at the local junk yard in a Festiva in the center slot of the fuse block but it wasn't Red like the one I blew. The covering on this wire is gray and it is stamped on the insulation "2.0 SQ. mm fusible link". Does anyone know if this is the proper size (25 amp) for my 1990 Festiva? Can't recall the year of the one at the junkyard
