Deep breaths man. That seriously sucks, but it's nothing that can't be fixed with the next size up thread tap + bolts. Your almost there!
Mating engine to trans
Hmmmmmm! ..... I just happen .... to have .... a .... 10 x 1.25 mm .... Heli-Coil kit! .... You can "borrow" the kit, use 3 of the Heli-Coils, use the tap, and install tool ....Originally posted by Chobobulous View PostI have now stripped the threads of three bolts.
.... all for the price of shipping it to you, and back to me!
Just last week, I had a stripped out thread in the 5 spd, I am putting in Black Car. I have 11 heli-coil inserts left! I don't think I will ever use them all. lol
I would think it would be around 6-7 bucks to do that.
PM me ....Last edited by drddan; 07-13-2014, 02:18 AM.Dan
I gave the main thread size on post #17, 2 posts above yours ...M10x1.25 thread. Length I will have to measure to be sure, but I think 25 mm longOriginally posted by jefferson83 View Postdoes anyone here know the size/length and thread count for the bolts that hold the tranny to the engine? I bought a bp seperated from a tranny and i dont have any bolts to remount with, its been a struggle to find info on thisLast edited by drddan; 08-11-2014, 02:00 AM.Dan
Gotta have the clutch alignment tool. I fought my last one putting it back together until I used the alignment tool. Trick is to wiggle it around making sure it moves freely within the clutch splines while tightening the pressure plate. This way when the input shaft goes in everything is aligned.1988 Ford Festiva "Sonic" BPT g25mr MS2 standalone ecu, FOTY '11, Best Beater FMV, Fan Favorite FMVI
1989 Ford Mustang GT 5.slow
1996 Ford F-150
I'm with Flyin on this one, if its going all the way to within 1/4" the clutch splines themselves are already engaged on the input shaft, but if the clutch plate is off center even a little bit then it won't want to seat into the pilot bearing. If its been tightened down enough to strip out threads then its not the backing plate binding on the axle that is causing the problem, though that is usually a point of trouble when reinstalling an engine with the axle in. I always notch mine about 1/4", just to make things smoother for installation.No festiva for me ATM...
