Shifter Problems!
  • Shifter Problems!
    I have never really owned or worked on a manual transmission until my Festiva. Well, the shifter has always been loose. You can wiggle it around in gear. Now it has developed a new problem. It's not lining up to shift into the gears. It takes some forcing to get it to line up. Has anyone had this problem? Or at least know how to fix it?
    Check your bushings.
      And you Trans fluid.
      Check out skimsukas post on bushings.
      Do a search.
      Bushings can be ordered at your local Mazda dealer.
      Thread title is "Shifter sloppiness solved"
      All the Part #'s are there.
      '93 Green L - ' Tiva
        Bushings also available from Kia dealer, though mine had to be ordered-about $ 12 for 4.
        "Wenona"-89L parts car
          If you want nice crisp shifts, have lots of money to burn and don't like crawling under the car often, then I recommend bronzoil. I would also recommend inspecting the nylon seats on the shifter pivot ball for cracks.
            I replaced the rear shifter bushing with one made out of 1/2" copper pipe. Cut 1.25" length of pipe and cut 3/8" wedge out of piece lengthwise, then close the wedge. There are 8 photos at www.photobucket.com under userid ag384fb. I did it because I was having trouble getting teh car to shift into 1st and 2nd gears. The shifter was too loose to throw the lever over far enough to get into those gears without catching.
              This the way to go:
                Originally posted by Pu241 View Post
                As I said.
                Thanks PU.
                People are always tryin' to make it hard, its not.
                  Gil, please let us know what your final decision was. Copper pipe, plastic or bronzoil bushings from Corksport.
                    Here's a link to photos of making the bushing out of copper pipe...
