Here is a video of problem it doesn't have this problem idling and only comes on intermittently while driving. The only things electronicly that remains from aspire engine is TPS and IAC valve sensor (both are spliced into ecu harness) the EGR sensor has been disabled and im currently making an adapter to put on old TPS and IAC sensors back on and completely removing EGR and putting alum plate over were it was mounted.
Also I'm not sure were this vacuum line used to go to on the ford aspire and if it is even needed any more, I have removed 2 vacuum lines related to EGR so far.
http://i.imgur.com/RfPljT3.jpg
I have no idea what this line is if its a vacuum line or coolant line or something else? it runs off side of ford festiva transmission and atm the unknown vacuum line it attached to it.
http://i.imgur.com/ZB72TAC.jpg
http://i.imgur.com/fc06vha.jpg
