So I tried to start it again this morning and still just click click click click click click click click. This time I noticed smoke coming from under the dash. Is it a messed up starter or possibly just the relay?
Starter help
Aw crap you let the smoke out!
Its totaled!
Haha not really its a wiring connection issue. You probably smelled something funky, that was wires burning or the solenoid finally crapped cause you let it click too long. Could have been as simple as a battery connector wasn't tight enough, now it could be a bad solenoid too. Check all the connections battery to starter, make sure they're tight and try again.
Starter relay?!Last edited by zoom zoom; 08-03-2014, 08:31 PM.2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
Repair help questions don't really belong in the general discussion forum
Thread moved
Originally posted by Chobobulous View PostSorry about that I thought I picked repair.
Anyways I ended up plugging in a relay that said timer buzzer on it. It buzzed. So I unplugged it.
Problem ended up being a loose ground. The one that was loose was seemingly unrelated to the starter
What is the buzzer module for?
For when the engine is running and someone opens the door it will sound. Though after all these years, mine doesn't always work.1991 Ford Festiva BP (Full Aspire/Rio Swap) (337k Miles) (Around 95k Engine)
