Starter help
  • Starter help
    So I tried to start it again this morning and still just click click click click click click click click. This time I noticed smoke coming from under the dash. Is it a messed up starter or possibly just the relay?
    06 Jeep Cherokee Overland
    95 Aspire (sold)
    Aw crap you let the smoke out!
    Its totaled!
    Haha not really its a wiring connection issue. You probably smelled something funky, that was wires burning or the solenoid finally crapped cause you let it click too long. Could have been as simple as a battery connector wasn't tight enough, now it could be a bad solenoid too. Check all the connections battery to starter, make sure they're tight and try again.
    Starter relay?!
    2008 Kia Rio- new beater
    1993 Festiva- Fiona, DD
    1997 Aspire- Babyspire, DD
    1994 Aspire - Project Kiazord
    1994 Aspire- Crustyspire, RIP
      Ill double check the battery terminals. I checked the 2 wires going to the starter 2 times. When I disconnect the spade one there is one click from under the dash.
      95 Aspire (sold)
        Repair help questions don't really belong in the general discussion forum
        Thread moved
          Sorry about that I thought I picked repair.
          Anyways I ended up plugging in a relay that said timer buzzer on it. It buzzed. So I unplugged it.
          Problem ended up being a loose ground. The one that was loose was seemingly unrelated to the starter
          What is the buzzer module for?
          95 Aspire (sold)
            For when the engine is running and someone opens the door it will sound. Though after all these years, mine doesn't always work.
