Drivers Side Rear Hub won't come off...
    Wow! Thanks for 'stopping me right there' Pu241. I will work on getting those nuts off.
      And thanks the reverend again for stopping you! He is quite correct, but first:
      Allow me to congratulate you for getting it off in the first place! I am astounded you managed it, somewhere on this forum, I recall someone using another vehicle to try to tank that hub off in that situation, to no avail!
      You pull the nuts off the backside of the assembly. To get to one of them requires removing the retaining bolt for the strut. Then the spindle pulls out, where they go through they are splined and causing them to rotate will ruin them.
        Is it all fixed and back on the road?
