My bp car keeps killing batteries so I swapped the alt and still did it then i put a good batt in and fired rite up. So i drove it and parked it then it would not start again! What other components are part of the charging systems that could be causing this?
charging system issues
Mine was because the belt wasnt tight enough so it wasnt properly charging the battery.
If it was too tight it would screech.. make sure the belt is tracking straight. Also, what bracket/bolts/nuts are you using to keep the alt in place?1993 Festiva L "Wendy" BP n' stuff
2013 Mazdaspeed 3 "The Kraken" -Stock.
Dave Forget
Originally posted by defprun View PostMine was because the belt wasnt tight enough so it wasnt properly charging the battery.
