i need to get a complete engine gasket set..... is there a recommended set?
locally, i can get a fel pro set, at the cost of roughly 140 bucks
rock auto shows a few:
ITM
DNJ
Auto 7
Sealed power
is there a reason to go with one over another?
reason being, i have to do the rear main seal on the festiva, i figure the oil pan has a slight weep, and i might as well just go ahead and pop the head, do a quick valve check(valve job if necessary) timing belt, water pump, oil pump, and check the crank main and rod bearings while i have it apart. i dont like doing things twice, but don't see a reason to do a full rebuild. (110,000 miles)
thanks for the help.
cheers
ITM
DNJ
Auto 7
Sealed power
cheers
