Hey guys, I have an idle issue with the 92 GL I have recently gotten running. It has a high idle on start up, and idle comes down slightly, but stays kinda high after.
On start idle is around 2000prm, and comes down to 1400 rpm. After it drops to 1400, if revved and then let it settle, it will again stay at 2000 for a bit and then slowly drop to about 1400 again..
I have talked to member William about this, and he thinks the IAC may be sticking. He said he tried to clean his, and free it up, but wound up disconnecting it.
Is there a good way to fix the IAC? or check it?
I also tried finding one on Rockauto, and couldn't find one. They did list an IAC connector, but not the IAC, itself. Part stores not listing one either. Maybe they are calling the IAC something else? Haynes doesn't mention IAC either.
I somehow managed to NOT set it on fire. LOL
