we started looking at the motor today and dh now things that it needs a head gasket. we found antifreeze in intake is this a right assumtion?ty1 for the help.
help with a festy
Check the intake manifold gasket, that has definitely failed if you have coolant in the intake. As far as i know, that is the ONLY way coolant can get into the intake because the coolant flows through the bottom portion of that manifold.Originally posted by alharper1981 View Postwe started looking at the motor today and dh now things that it needs a head gasket. we found antifreeze in intake is this a right assumtion?ty1 for the help.Last edited by TorqueEffect; 09-24-2014, 08:50 PM.1991 Ford Festiva BP (Full Aspire/Rio Swap) (337k Miles) (Around 95k Engine)
