All of my other lights work just fine. Bulbs arent burnt and the fuses are fine? is there anything else i can check? taking it somewhere is not an option i would appreciate any help thanks.
Headlights wont come on
Cought, check your fuseable links. There are 3. One is the ECM, one is the main (engine will crank but not run), and the other is the head lights. They are located on the driver side inner fender. I haven't had any luck buying these links so I make my own and always carry a couple spares in the glove box. Good luck. Mike90 Festiva L
