How to tell whats bad if the tire wiggles both at 3/9 and 12/6...
  • How to tell whats bad if the tire wiggles both at 3/9 and 12/6...
    Tie rod, wheel bearing, control arm? I was thinking control arm but not for sure. What think you? Could be wheel bearing too, is making some noise.
    if it is at both of those positions, it would lead me to think wheel bearing. the best way to do it is to have someone else slide under the car while you wiggle it. ( or vice versa ) and look at the tie-rod end and then the hub while wiggling. that will def help narrow it down.
      You started a new thread for the same problem.WHY? I told you exactly how to check if its a bearing etc
        Well, I'm 52 so maybe I'm not remembering to well. What post was it where you "told me exactly how to check". Sorry I didn't check with you before posting. Next time I'll contact the posting nazi before proceeding
          LMAO! I'm sure glad to see I'm not the only old guy who might get on here and make a mistake. HaHaHaHaHa...................... Thanks jimdigs!!
            We are contemplating starting an elite group of posting storm-troopers, to act as a posting SWAT team.
              Try tightening the lug nuts. I know someone who had her car towed.
