So my car needs an alternator. There's a 45 and 50 amp that I see available. Is the 50 for the automatic? Or does it matter? Also, since noone seems to have these in stock (and I need one asap), is there one listed for another car that will work? Any other Mazda or anything? I need to know soon! Thanks for your help!
Which alternator? *Urgent*
Do you have an alternator/starter repair shop in your area? They should be able to repair your alternator. It's possible they might have one on the shelf.Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
I believe if you have 88-89 year Festy, you can switch the plugs on the harness to fit the newer style alt. Most Mazda alt from the 90's will fit then, and can get higher amp alt then. I read somewhere a member had a 90 amp alt. Don't remember what it was from, but it was a Mazda.Last edited by drddan; 10-06-2014, 12:49 PM.Dan
Probe alt here, it's 7mm larger, so the top bracket must get adjusted, but 90 amp, doesn't work very hard to power everything-Greg
Redneck Engineer
FOTY - '09
