I am new to festivas. My 93 festiva was running great until one day i put it on the interstate for a few miles. When i went to get off the exit ramp and pushed the clutch the engine speed never came down. Now when you start the car it goes straight to what sounds like 4000 rpm! The car doesn't have a tach but it is extremely high. I found a used IAC valve and changed that. Did not help. Any suggestions would be greatly appreciated.
idle extremely high
Had to back off the screw on my 92 dashpot to get it to stop causing a high idle. It would start at 3000/3200 rpm and s-l-o-w-l-y drop down to 2000, sometimes 1700.
Then it still had a slight high idle about 1500, had to adjust the idle screw on top of the throttle body to get it down to 700.Dan
Thanks for the responses guys. I checked the dashpot and i think that might have been the culprit! I lubed it and worked it back and forth a few times and it seemed to be alot better on my test drive. .. in the meantime while it was sitting the battery went dead. I changed the battery but now i have no headlights. All the others are working fine. I checked the fuse link under the hood. It is good. I can hear a fast continuous clicking near the battery. It sounds like a relay. But now I'm having trouble finding one at the part stores.
The headlights and park lights both have there own separate relays. That was the fast clicking you heard...Originally posted by tomtucker84 View PostOk i. Checked all the battery connections and the battery voltage. Still no headlights. Checked all fuses under dash and fuse link under hood. All good. Still all lights working other than headlights. And not the bulbs either.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
