Originally posted by ajb999
Brake Problems (not a leak, I believe)
91 u.s. festiva L 189423 mi. GL int. , engine started smoking [sold]
93 u.s. festiva gl 222000 mi. bad engine , parts car [sold]
1981 ford F-100 400000+ miles ? , looks rough - runs good
1963 1/2 Ford Falcon 4 door base model , 106000 original miles , second owners
Well I was doing the brake job today and the inner pad wasn't lining up like the old pad did. I was wondering if this would be a problem. The bottom of the inner pad is a little farther towards the center of the rotor. Also there were no shims even though Haynes said there were two on one side and one on another.
Black '89 Ford Festiva L with 4 Speed Manual Transmission
By lining up , you mean top to bottom between the piston and the rotor ?
When you compressed the rotor ,did it go in the caliper straight or crooked .
Did you lube all the slides , pins and caliper bolts with caliper grease , so that the caliper applies both pads evenly .------------------------------------------------
HD2500 Duramax Chevy
Z28 LS1 power 500 +
Okay I've got to looking around and at the bottom of the master cylinder where it connects to the booster it's leaking a little fluid (not a lot) but apparently enough to let air in the system or not keep pressure. Does this mean it's just a seal between the master cylinder and the booster?
I am pretty sure there is no actual seal in between the 2 .
If you have fluid leaking from there ,it is leaking out the back of the master cyl itself ,and running down the booster .
The seal inside of the cylinder has to be leaking where the rod goes into the booster .
It sounds like it really needs replaced ,, cheaper ?? much easier than rebuilding one !!------------------------------------------------
Z28 LS1 power 500 +
