Do you think I should spend the time trying to repair a 1991 Festiva motor where the engine had a massive oil leak and then locked up? Have you ever brought one back to life where that happened?
My first thought would be to simply start taking the head off, remove the plugs and put a little oil on the pistons, try to get it rotating, remove the pistons, check out the rod bearings, rings, and valves, check out the surface of the crank shaft where the rod bearings go, check out the cylinder walls, and then diagnose and go from there. What are your thoughts?
