Hello all!
I found a 95' Aspire with an EFI engine in a junk yard. I want to rebuild the engine and install it in my vehicle using the 88 carb setup (I'm planning on buying a weber carb to install at a later date). My question is, can I use just the engine from the Aspire and put the carb on it, or is there barriers to doing this? Thank you all for any advice given.
