It seems most all the Festivas I've owned have door seal problems. The top of the drivers door doesn't seat all the way shut properly and you can always hear loud wind through it and also see the top of it shaking. The rubber seals up there seem to be ok. It's as if the door just needs to be able to shut more...like adjusting the hinges or something. Does anyone know of a fix for this problem?
A Lot of Wind and Noise Through the Door at the Top
Roll the glass down and bend the door frame a little further in.
Shut the door on a piece of paper and pull it to check for resistance.
Continue to adjust until there is equal resistance at all points between the door and the body.Last edited by bravekozak; 01-10-2015, 08:18 AM.
Just adjusting the strike so that the door lined up better with the body helped mine a lot."Blue92"- 92L 5 spd, original owner- 185K, B8,DD..
"Pedro"-88L 5-spd, B6D (built by Advancedynamix)
"Blanca"-92 GL auto, 125K(FM8 Lowest Miles)- B6 daughter's DD
"Tractor Blue"- 89 L auto, 110K
"Chester"-88 LX, runs but not street legal
"Wenona"-89L parts car
"Flame"- 89 LX 5 spd ,parts car
Been there, done that! I need to do the drivers door on the GL. No more noise.Originally posted by bravekozak View PostRoll the glass down and bend the door frame a little further in.
Continue to adjust until there is equal resistance at all points between the door and the body.Dan
It's not unusual for people to bring new cars in to the dealership, I'm told, with door noise complaints, and they are surprised to the see mechanic bend the door.
Rick
1993 Ford Festiva
2000 Ford E350
That video must be staged.
Then again, that's how we "rig" little airplanes that lack pilot-controllable "trim tabs" on the control surfaces to fly straight. We hand-bend the fixed trim tabs (which are nothing but a rectangular piece of 0.040" aluminum riveted onto the trailing edge of the control surface) by trial and error until the airplane flies straight and level with the pilot not touching the controls.88L black, dailydriver
88LX silver a/c, dailydriver
4 88/89 disassembled
91L green
91GL aqua pwrsteer
92GL red a/c reardmg
1952 Cessna170B floatplane
