I have a 91 L model, I am planning on swapping the motor. However, I do not have an engine hoist. How can I get it out without one?
Need help removing engine
Old swing set. Motor weighs 250 with everything on it-Greg
Redneck Engineer
FOTY - '09
I've pulled one out with a person lift, like what they use in the nursing home. They are good for about 250lbs if your careful. (That was 10 years ago and I have a proper cherry picker now )Last edited by nonamekid; 01-22-2015, 08:36 PM.The Festiva Store
Many years ago, wife and I removed the engine with a 2X4 and coat hangers, one of us on each side, squat, shoulder under the 2X4, lift.
I would replace the coat hangers with a ratcheting tie down strap.Contact me for information about Festiva Madness!
Originally posted by scitzz View PostMany years ago, wife and I removed the engine with a 2X4 and coat hangers, one of us on each side, squat, shoulder under the 2X4, lift.
I would replace the coat hangers with a ratcheting tie down strap.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Originally posted by TominMO View PostAgreed; also I would use a 4x4, and screw a piece of angle-iron onto the bottom side for extra strength. May or may not be necessary
Scitzz means crazy, Yo!
But you have to be a little crazy to spend time on these cars, right?Contact me for information about Festiva Madness!
