daughter has a 92 festiva, stick and my boy was checking the fluids and opened the air breather to check the filter and now it won't run. it will start but then dies right after. could it be that he jared the mass air flow sensor? i had the top of the air breather off and the flapper door moves in the air stream but thats as far as i have checked. please help on any fixes. thanks.
starts, then dies? any fixes...
did he disconnect the wiring at the sensor? if so, check the connectors to see if something is mis-aligned.91 u.s. festiva L 189423 mi. GL int. , engine started smoking [sold]
93 u.s. festiva gl 222000 mi. bad engine , parts car [sold]
1981 ford F-100 400000+ miles ? , looks rough - runs good
1963 1/2 Ford Falcon 4 door base model , 106000 original miles , second owners
make sure it's plugged in.
inspect the rubber intake tube going to the intake manifold, especially the acordian tube just before the left turn in the tube for any holes and also make sure all of the tubes going to the intake tube is tight.
THERE CAN NOT BE ANY HOLES TO THE OUTSIDE AIR BETWEEN THE THROTTLE BODY AND THE AIRBOX!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
OR IT WILL DO EXACTLY WHAT YOU ARE TELLING US ITS DOING
The same behavior will also occur if you unscrew the screws that hold the connector on the air mass flow meter and try to remove the wired connector!
Best thing to do is swap a working AMF meter for a known good one!
Where are you located?
Pu241'93 Blue 5spd 230K(down for clutch and overall maintanence)
