So I have a leak. I just replaced the timing belt and both seals upper and lower. I gambled on not doing the inner seal behind the oil pump for some reason. I thought doing the outer seal would be enough but its still leaking and just seems to be getting worse. i'm wondering if its more likely the oil pan gasket or the inner seal. it seems to be contacting the crank pulley and gets slung about the engine bay. Thanks in advanced
oil leaking from timing belt side still.
Clean off the area with brake cleaner (in aerosol can), drive it, then look to see exact point of leakage. Check both the camshaft seal and the crank seal. The inner oil pump seal would not affect leakage outside the motor. The oil pan gasket is probably not the problem either, but it might be if the motor is very high-mileage.
The crankshaft seal might be the problem, as it is on my Aspire, due to an imperfection on the crank itself, like a scratch where the gasket is--maybe a previous repairer gouged the crank with a screwdriver or something. In that case, try installing a new seal (you will probably destroy the one you just installed when you remove it), but don't install it totally flush with the block; leave it about 1mm sticking out, to hopefully get past the scratch or whatever it is.Last edited by TominMO; 02-18-2015, 12:08 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Oil pan RARELY leak. I doubt it is the pan. Check crank seal.Dan
+1, don't open up a can of worms by doing the oil pan first. Check crank seal!Originally posted by drddan View PostOil pan RARELY leak. I doubt it is the pan. Check crank seal.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
