Go to your cranking enrichment setting and move them down for your temp at what you are cranking and move the whole bar down a tad till it starts better.
After it starts if it is rich. Then you need to change the after start enrichment table down to lessen the fuel. You can do this while the car is running and watch where the blue dot is at and change the setting till you get a correct afr.
