I have an 89 carby 4 speed I know it calls for .044 gapping on the plugs but I also know you can open that up a bit for better power and fuel economy. Whats the best gapping and might as well if you know what are the best gaps for the EFI's too. Thanks guys
Optimal spark plug gaps?
You'll also eat plugs faster gapping them wider, and it'll be theoretically harder on the coil. Plugs aren't that expensive, but I've had to do new ones every 10k before because of excessive wear. That was also a wasted spark engine, so the Festiva won't be that bad.
I've gone as far as .065 in other cars. Never tried it in a Festiva though. If I were doing .065 in a Festiva I'd try to find a way to run dual coils. Don't know if you can do that or if it's even of any benefit, but I'd try to do it anyway.Any difference that makes no difference is no difference.
I have used .048. Not sure it made any difference. It ran good, but it did at .044 tooDan
Can't fix what isn't broke. Some of these salesman fishing videos..it looks so good I have to try the new bling bling lure. Spark plugs with split fire, multi electrodes, fire rings, sharp little edges, tiny points, fancy metals work the same way! NGK is still working for me. .040 or if turbo car or supercharged I like .028 . If it works good use it, if you get misfires change plugs or gap. It all makes good camp fire talk lolReflex paint by Langeman...Lifted...Tow Rig
If you mean mine, it's working for me.Any difference that makes no difference is no difference.
I just wanted to check ...Torrent link does not work for me, but the dropbox link does work
Torrent gives me ... This page can’t be displayedLast edited by drddan; 03-19-2015, 01:29 PM.Dan
That's because it's not a page.
You right-click it and copy the link location. Then paste into a torrent client. Or if you're setup to click to DL torrents from magnets it would work, but it's not a page by itself.
Just shows how dumb I can be on some things! lol
but I did just learn something! Thanks!Last edited by drddan; 03-19-2015, 03:59 PM.Dan
