There is no code 89 or 91. Maybe it's being read wrong, or those are 3 separate numbers, or a bad computer.
accelationd oun issue
It doesn't sound like you're describing a transmission problem, unless you're saying the engine speeds up without the car speeding up. It wouldn't hurt to check the vacuum hose going to the transmission vacuum diaphram. Check the fluid level hot and color too, if you haven't. It probably needs changing as many people are bad about getting that done every 30K miles.Originally posted by marinepolice03 View Posti replaced that and there is little chance in park, no change in gear, could it be something with the trans?When I'm good I'm very, very good and when I'm bad I'm HORRID.
If I have tomorrow off I am going to change the fuel filter. Here is that solenoid
1973 Cb750 haven't touched it yet with no idea what I am planning on doing with it
1978 25th Anniversary edition Corvette
1983 Chevy Elcamino
1993 Ford Festiva GL
2003 Hyundia Santa Fe ( Wifes Daily driver)
some old dodge motorhome I have no idea of the year
Very strange. Can you talk to the PO and see what he was trying to accomplish with all his little changes? Is he brilliant or goofy?90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
He is just goofy, I got a scolded because I smoke, drink Pepsi and because I'm a truck driver1973 Cb750 haven't touched it yet with no idea what I am planning on doing with it
1983 Chevy Elcamino
Yeah, what I suspected. Best to return all components to stock and see what happens. Plus the various tune-up items mentioned, etc.Originally posted by marinepolice03 View PostHe is just goofy90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Why do you have a fuel shot off solenoid , was this dual fuel ?
read the whole thing, so he the solenoid in the vacuum to the fuel regulator ?
What was the manual valve turning off or on ?
He must have had some ideas he wanted to try out.Last edited by Movin; 03-23-2015, 02:19 PM.Reflex paint by Langeman...Lifted...Tow Rig
No idea, it was the guy before me. Not dual fuel1973 Cb750 haven't touched it yet with no idea what I am planning on doing with it
1983 Chevy Elcamino
One thing to check is your fuel tank. Fold the back seat down, then forward. You'll see a square bump in the carpet. Under that is the fuel pump access panel. Remove the 4 screws and unplug the connector. Pull the panel back and disconnect the hoses and connectors there. Unscrew the pump (12 screws I believe) and take a look at the fuel in the tank. If it smells like turpentine, it pretty much is. That means phase separation has occurred (ethanol-laced fuel has sat for too long and is now destroying your fuel tank & pump) and you would do well to get a Harbor Freight hand siphon pump ($7) and a bucket, and remove the fuel quickly. Pour in some carb cleaner, let it sit, and then siphon that out too. Close everything up, add new fuel, CHANGE THE FILTER in the engine bay, and you might have solved more than one issue. If the fuel doesn't smell bad, you've done 2 things: Inspected the quality of your tank, and ensured that the sock (a pre-pump filter) isn't bad.In love with a MadScientist!:thumbright:
before the on/off i valve was between the fuel filter and the fuel rail ( why i dont know), today i checked and the fuel tank was fine, i replaced the fuel filter ( he had it in backwards, still ran odd, i tried to replace the regulator and nothing changed the one i put on looked new,i put the on/off valve on the fuel line coming out of the regulator and turned it off, and it solved the issue, still lags around 55mph, but ive never driven a auto b3 before so im not sure what " normal" feels like.1973 Cb750 haven't touched it yet with no idea what I am planning on doing with it
1983 Chevy Elcamino
Bad regulator? Closing off flow after the regulator will jack the rail pressure way up. Maybe the regulator is allowing too much flow past. Or the pump is weak.91GL BP/F3A with boost
i tried to open it up slightly and after 45 it takes alot longer to get up to speed.1973 Cb750 haven't touched it yet with no idea what I am planning on doing with it
1983 Chevy Elcamino
I can't believe it's not common practice but a vacuum gauge tells alot. My aspire 5 speed runs at 65 with 10 inches of vacuum. Closer to 16 with wind at the back, 5 with a strong head wind. I'd suspect the auto would see the lower end of that scale, but the gearing would have your engine running faster than mine
