shifter bracket
  • shifter bracket
    So my bracket that holds the shifter up, had it's tabs broken so my shifter keeps falling down. I've tried driving screws through it and they'll hold for about a week but then they fall down. My question, is there a way (short of welding it into place) to hold up the shifter?
    92 Ford Festiva GL- DD/WIP Deathstiva
    97 Ford Ranger 2.3l 5-speed- parts getter
    can you post a pic what i had to do for mine is i put screws in from the bottom under through the plate that holds the shifter up if i can get my phone to take a charge ill take a picture
    88 L carb'ed (when up in flames of glory)(deceased) 4spd
    89 L carb'ed (died on the operating table (rust))(deceased) 5spd
    93 gl FI (sold) automagical
    89 lx FI megasquirted "luna" b6D+t (186hp 209ftlbs)
    88 L carbFI megasquirted zombie car
      yeah that's what I've been doing but it keeps falling back through
        Do this
        http://www.fordfestiva.com/forums/sh...ifter+dropping
        Dan
          yep thats pretty much what i did altho i used about 1''1/2'' long selftapping screws instead of bolts are you using longenough screws
            That should work I've just been using self tapping screws
              Better to do it with a machine screw and a nylock nut, even some blue Loc-tite. Won't fall thru then.
              Pull the whole assembly out of the car, paint it if you feel like it, and put some spacers between the two pieces so they are parallel. I used a lug nut and a couple of washers as spacers.
                I just super glue it back together. Done this on two shifters and never had problems again.
                David
