Title says it all what's the right way to push them out of the knuckle? Thanks
removing races from knuckle. how?
I have also used a big flat screw driver. Slowly work all the way around so it doesn't get crooked inside it.
To reinstall I turned a race upside down, so the thin portion of the old one sat on the thin portion of the new one. Then gently tapped it in.Last edited by Chobobulous; 04-19-2015, 05:53 PM.
i just rented the bearing race tools from my local autozone easiest and safest way88 L carb'ed (when up in flames of glory)(deceased) 4spd
89 L carb'ed (died on the operating table (rust))(deceased) 5spd
93 gl FI (sold) automagical
89 lx FI megasquirted "luna" b6D+t (186hp 209ftlbs)
88 L carbFI megasquirted zombie car
If you don't have a punch a spike will do. An upside down spike makes a good punch. I have a 12" spike which gets a fair bit of use. Saves on ruining large screwdrivers using them as punches too.Last edited by WmWatt; 04-20-2015, 08:05 AM.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
I do this, but I take a grinder with a cutting blade, and cut a thin section out. That way it slips in and back out again with no real trouble.Originally posted by Chobobulous View Post
To reinstall I turned a race upside down, so the thin portion of the old one sat on the thin portion of the new one. Then gently tapped it in.Contact me for information about Festiva Madness!
Hey thanks guys. I got the races out and now I need to get a bearing puller to get the outer bearing off the shaft. I'm also curious. When I go to press this stuff back together how tight do I push it. I have a 50 ton press I use if anyone's wondering. This is first go around with this. I've learned so much from working on this car constantly. I don't think I ever stated that I'm working on the front end.Last edited by 2jzkilla; 04-23-2015, 12:59 PM.
Under one should move it, one maybe two should seat it. It should be quicker with a hammer, vise and maybe an air hammer. Most important is to note the slight increase in rotating torque when tightening the big nut. That way you know you have the right spacer back between the bearings. This spacer and what it adjusts has been the biggest source of grief by far. Use anything except Timken bearings. Any old grease will do.
lol, follow those last two things and practice will make perfect! I like Red Line synthetic grease and USA or German made bearings. Japan made maybe. If Chinese is all you can get then set specs exactly on the minimum preload and use the best grease you can get. A hardwood bearing with pressure charred surfaces and bear grease will outlast Chinese bearings.Reflex paint by Langeman...Lifted...Tow Rig
