Oil Help Diagnose!
  • Oil Help Diagnose!
    So heres the pic of my oil, it looks milky in the pic but its like really really small gold looking shinny flakes, like almost microscopic
    What do you guys think it is from?
    antifreeze
      I can't think of any bronze bushings in the engine.. Was the drain pan dirty before you started?
      -Zack
        Engine rebuild in a can ? It must be brand new! lol
          It could be copper flakes from really worn rod or main bearings. Once you get the silver/gray metal worn off the bearings, it's copper underneath.
          You gonna race that thing?
            Looks like you struck oil and gold at the same time.
              You use any oil additives? What kind of oil pressure does it have?
              N3WBI3
                Metal flakes in oil can look gold-ish or bronze-ish, even steel or alum flakes. Are you sure that's not antifreeze?
                Dan
                  Was it making noise .knocking? Metal flake in the oil and milk shake looking oil is usually a blown head gasket driven long enough with water in the oil that it wipes out the bearings.The rod bearings go 1st and create a very audible knock.
                    I did find a piece of metal in the oil pan, looked like a broken piece of a piston ring, but got 180psi across all cylinders
                      haha the engine only has about 15000-20000 miles on it, also has ACL racing bearings
                        Same with ACL racing bearings? no knock engine runs fine
                          no oil additives and I need to check that out
                            Im pretty damn sure, its sparkly and not milky like how blown gaskets would be, Ive seen quite a bit of blown head gaskets oil
                              no knock what so ever! idles good, pretty quiet
