Brake Pad Pin Clip?
  • Brake Pad Pin Clip?
    Hi all, quick question from a newbie here on the forum.
    I'm replacing the front brake pads on my Dad's 1989 Festiva, following the Haynes manual.
    I got to the point where it says to remove the "W" retaining clip that holds in the pins, but on my car, it was a loop of wire running through the holes that I had to break to get out in order to be able to remove the pins.
    The question: can I somehow source the correct "W" clip? Or should I just do what the person before me did and find some wire, run it through the holes in the pins and be done with it?
    Thanks.
    I personally like using those mini cotter pin type clips.
    They never come loose.
      Rock Auto sells them. You could get a whole new hardware kit starting at $1.48 (plus shipping)
      Brake & Wheel Hub Parts and More for Your 1989 FORD FESTIVA at Reliably Low Prices. Fast Online Catalog. DIY-Easy. Your Choice of Quality. Full Manufacturer Warranty.
      93 GL
        always thought the W shape wire was an anti rattle. there is another wire with half loops on each end that goes through the pins holes. but the little clevis type pins in some kits are a lot easier.
          Rockauto has a WHOLESALER CLOSEOUT FESTIVA PART SALE RIGHT NOW! Just got an email from them and I was about to post a thread about it
          http://www.rockauto.com/RSS/vehiclef...l=en&html=true
          Dan
