could the accessory pully from the aspire work on my festy
  • could the accessory pully from the aspire work on my festy
    I got all the parts i just bent the accessory pully getting it out. So I've been looking for a replacemen. Aspire I've been working on had ac so could i use just the pully or would i need the inner pully as well?
    Anyone know if the inner pullys are the same or would i need both pullys to in order to use the accessory pully from an aspire on my festy?
      I can't remember for sure, but I don't think it will work. For one thing, the Aspire crank is bigger. Might possibly work if your car is a '93.
        Aspire pulley will only fit the '93 and some later '92 festiva motors. Different center bore and bolt pattern on the crank. Also, the Aspire will have a ribbed A/C pulley. If you have a later year festiva and can use the Aspire belt tensioner and compressor (both will bolt up to any Festiva motor) it should work.
        No festiva for me ATM...
          I have a 93 so it might work The pully i have is ribbed and the system i have came off a festiva that had ac I'm pretty sure that car was a 93 aswell. i bent the pully getting it out in the junk yard cuz I'm dumb. I guess the question is should i use a slightly bent pully. .. it's just the outside lip is wobbling inside is still straight.
