I got all the parts i just bent the accessory pully getting it out. So I've been looking for a replacemen. Aspire I've been working on had ac so could i use just the pully or would i need the inner pully as well?
could the accessory pully from the aspire work on my festy
Aspire pulley will only fit the '93 and some later '92 festiva motors. Different center bore and bolt pattern on the crank. Also, the Aspire will have a ribbed A/C pulley. If you have a later year festiva and can use the Aspire belt tensioner and compressor (both will bolt up to any Festiva motor) it should work.No festiva for me ATM...
I have a 93 so it might work The pully i have is ribbed and the system i have came off a festiva that had ac I'm pretty sure that car was a 93 aswell. i bent the pully getting it out in the junk yard cuz I'm dumb. I guess the question is should i use a slightly bent pully. .. it's just the outside lip is wobbling inside is still straight.Last edited by 2jzkilla; 05-18-2015, 02:30 PM.
