For a 1991 North American Festiva, is the inlet hose closest to the drivers side or the hose closest to the passenger side? Also, which connector do I pull to force the cooling fan to run continuously, the connector on the thermostat housing or the other connector closer to the passenger side of the car? Thanks
Coolant flush, which hose is inlet for heater core?
Correct.Originally posted by bravekozak View PostCorrect me if I'm wrong. I believe the inlet hose is the one closest to the passenger side.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
.... and use CascadeLast edited by drddan; 05-08-2015, 04:22 PM.Dan
