Today I went out and fixed my Aspire's parking brake pivot; the one inside the brake drum that gets rusty and keeps the parking brake on.
Inspired by Advancedynamix's shifter fix, I decided to use nylon washers as thrust bearings, to eliminate any chance of them rusting together in the future, along with stainless fasteners.
The pic below needs to be corrected in two ways:
1. I also put a nylon washer between the screw head and the pivot arm; and
2. I reversed the position of the screw head and nylock nut. You want the smaller screw head on top, to clear the inside of the brake shoe better. In the picture, the assembled pivot arm in the background is for the passenger side, and the nut as shown is on top.
Using the nylock nut means I could adjust the tension to loose enough without being floppy. And the stainless fasteners of course won't rust. They are 1/4" screws, and slightly loose in the holes they pass thru.
On an Aspire, the pivot halves are held in place by one of those two rivets you see. They are secured by a washer thingy that crimps on. I don't know the proper name for it. This might also be true for later Festys like the '93 that comes with the nut cage and cotter pin instead of the crush nut, but IDK. My '90 Festy has a rivet that you have to grind off one end to get it off, instead of the crimping washer.
I'm hoping this fixes this little issue forever. I'll take another, corrected pic tmw.
