Fixing a seized parking brake pivot
  • #16
    Originally posted by Dragonhealer View Post
    I am crying for you guys with all that rust !
    Tom, conventional engineering wants to have a smooth shank in the pivot area, does pivoting on threads work long term? does that help keep the pivot clean? Or hold more lube? Just wondering.
    I laugh at conventional engineering.
    I reject your reality and substitute my own.
    You seem to be operating under the delusion that I (a) have a plan, and (b) know what I am doing.....
    • #17
      No delusion, just my reality!
      Conventional engineering should never preclude creativity, though I often use it in unconventional ways.
      And of course you know what your doing, it's your reality stream.
      Now where did I put my glasses?......
      No car too fast !
      • #18
        I too have bolts there and when you think of it there is less surface area amongst the threads to rust and bind however the best rust prevention is to use the *#@ parking brake.
        • #19
          ^ that man speaks the truth!
          • #20
            No contest there, the best way to preserve the whole car is to use it!
            No car too fast !
            • #21
              The other side with the spring is suppose to pivot too correct? Mine are froze to heck and back. Currently have them soaking in Apple Cider Vinegar to remove rust on them.
              Current cars:
              • #22
                On parking brakes: heard a long time ago...........use them all the time , or never.............
                • #23
                  I put mine in a vise one at a time and hit them with penetrating oil and a hammer for a couple of days until they broke free.
                  • #24
                    OMG, you must have been soooo tired afterwards.....
                    • #25
                      I have fixed a couple sets of these using the electrolysis rust removal method. Just get everything hooked up and let run two or three days. Completely de-grease and repaint, also you can spray graphite lube in the moving joints. It dries super hard so it wears off very slowly and will slow down future rust. If you have the graphite lube out you should also do you door latches for a smooth fresh feel.
                      Also you can still buy new brake adjusters/ ebrake things through fourgreen if you want that fresh OEM zinc look.
                      • #26
                        I use a small map gas torch, put the two piece e brake parts in a vice, light torch, apply heat, two minutes late things are free, let cool, now knock out the rivet, you now have two pieces, clean them on a wire wheel, run to the parts store, buy a shoulder bolt with the correct nut, make sure the new bolt is smaller in diameter than the hole you are putting it in, the shoulder bolt is like the rivet you removed, but with a removable nut, when putting back together, I use NAPA Green Grease, it's very good at sealing the area that you just cleaned and it's good at keeping water out, it's main use is for Boat trailer axles. Good luck. oh the Green Grease is good at resisting corrosion.
                        • #27
                          Nice improvements on my effective (but typically half-a$$ed) solutions. :-)
                          • #28
                            your way works just fine, my way is just different, it all works.
