Looking to replace the rear tranny mount in the Festy. I want to do it without pulling the motor and tranny. It looks possible, but just for a sanity check tell me if this sounds right:
1. support tranny with jack/block of wood on the left side, under the battery tray
2. remove nuts from front and rear tranny mounts where they connect to the crossmember
3. remove the four crossmember mounting bolts; drop crossmember
4. remove the two fasteners that connect the rear tranny mount to the tranny itself
5. replace with new mount; reassemble
Sound about right? Any tricks of the trade?
