So i've got my transmission out to replace the clutch, anything else i should do while its off? I got a rear main seal coming then im going to replace as well. Also before i tore it down i had some problems getting into 4th gear (its a 4spd) anything i should look for in the transmission that could cause this? Or could bad shift linkage bushings cause that?
Things to do while the transmission is out
New axle seals
New bearings
New phantom grip lsd
Dimple world's strongest magnetic drain plug
Clutch
Pressure plate
Flywheel
Pilot bearing
Throw out bearing
Front & rear mounts
Shifter bushings?Last edited by rmoltis; 06-01-2015, 07:10 PM.
Sorry to disagree with shadetree. But its not a new car. Its a 26 yo car. Age is almost as damaging as miles are. Rust, dry seals, etc.
Example. I knew of a 12 yo car with 26k miles. Went for a ride. Got towed to a shop because the brakes were rusted and would not retract. This car had already had the radiator replaced.
Bushings and linkage can cause difficulty hitting the gate, transmission oil can cause a slow stiff shift. A bad clutch can too but you should be complaining about additional symptoms for the clutch to contribute to a stiff shift.
Clean up spots that you can't reach with the transmission installed, look at your coolant pipe and the little bypass hoses. Your starter should go for a while yet and its not that hard to do. Look for coolant crusties around the adapter housing to head. Look for oil seeping through the disty, all easy to see with the trans out. Axle seals and boots? Depending on humidity, climate, proximity to salt air or/and salt roads and exposure to sunlight there may be more to check! The best tool is you, touch, feel, jiggle and look carefully! Your girl might tell you that too lolReflex paint by Langeman...Lifted...Tow Rig
If it ain't broke, don't fix it. Every time you remove something you take a risk of maikng it worse than just leaving things as they are, plus the added, and possibly wasted, time and money spent. What I do is look everything over, use a wire brish to clean up any fasters, and smear them with gease to slow down rust in case I need to remove them some day.Last edited by WmWatt; 06-02-2015, 07:54 AM.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
