Hello, I do not have much time and would like a well versed Festiva mechanic to swap out my rotors. This was last done October 2010 and I just replaced pads yesterday. I live in Alsip, IL - just South of Chicago. I have rotors and is the stock set up. Thanks in advance for any assistance, Al
Southern Chicago South Surburban Mechanic wanted to swap out rotors...
Please read thread 56867. I believe he is selling exactly what you are looking for!Last edited by bravekozak; 07-04-2015, 04:09 PM.
Wish I cold help but I got nothing to press rotors with. I'm sure any Midas or similar can do it cheaply. It's not rocket science.Last edited by Hot_Wheels; 07-04-2015, 10:23 PM.
You don't need a press and if you have someone do it for you make sure the reuse the spacers in between the two bearings.the reason for the different thicknesses of the shims is to make up for variances in the front raring housing and hub if you are reusing your hubs and housings your shims will be right if you aren"t using grade zero cheap bearings.All you need to do these is a slide hammer a hammer misc. hand tools an some blocks of wood.I f you want me to give you the procedure. shoot me your phone number and I'll walk you through it.30 + Vehicle projects right now.7 Festiva/Mazda 10 GM IDK how many others,hope that helps explain all the stupid questions/shortcuts/interchanges etc. trying to liquidate so I concentrate on the good ones. Goal finish 1 amonth using as much stuff as I already have accumulated.
Well good for you glad it worked out.
Have a great day30 + Vehicle projects right now.7 Festiva/Mazda 10 GM IDK how many others,hope that helps explain all the stupid questions/shortcuts/interchanges etc. trying to liquidate so I concentrate on the good ones. Goal finish 1 amonth using as much stuff as I already have accumulated.
